question on trim tab
Status
Not open for further replies.
HFD56
I just purchased a 91 21 ft Baja with 7.4 magnum alpha one drive my question is should this outdrive have a trim tab i can,t tell if one is missing or it never had one.Any help would be appreciatted Thanks
Bob_VT
Re: question on trim tab
People have been known to remove them on higher powered outdrives to accomodate a larger prop. Look right above the prop on the cavitation plate it should be a vertical slightly wing shaped piece of metal. Then again it might be gone.<br /><br />Bob
HFD56
it currently doesn,t have one there and it has a mirage plus prop on it but not sure of the size
Walter
Fone_Man responded to a similar question some months ago. He said Merc has all but eliminated the "trim tab" and instead installs a sacrificial zinc plate in it's place. It looks and mounts like the old trim tab...only it's a flat disk with no "skeg". My Merc tech buddy told me the same thing. He said with power steering, you'll notice no increase in prop torque with the flat disk vs. the older style. However, you should have one type or the other installed due to it's anti-corrosion function.<br /><br />Walt
HFD56
Thanks walter,i do have the flat disc there so that completly answers my question thanks again
Status
