seanymph85
- Nov 5, 2013
- 199
I have a 1985 Sea Nymph 14R Big Water and will be using Gluvit on the inside seams in the bow of my boat soon. I need to know if it is okay to do the reseal in 2-3 stages. For example sealing a small area in the lowest (bottom) end of the bow, then turning boat on one side and sealing seam on one side of center of bow and after that has set or cured turn boat over onto the other side and then seal that area.
I ask if this type of procedure is okay as I would think the Gluvit would seep into certain areas better when the boat is either in the normal upright position on the trailer and or off the trailer and on each side. Even if it is thick enough to stay where it is put there is not much room in the inside of the bow area to try to press or work it into the seams. So I thought it might work into various areas of the bow seams better when the boat is in several different positions appropriate to the area being sealed.
Any input on this would be appreciated!
