question re: integral trim tilt ram
CWKboat
Hi, I have a 1987 115 w the Integral trim. Whenever it is engaged inside the trim brackets it will not bleed down or move down whatsover when applying downward pressure; however, it will move up an inch or so and has play in it coming back up if you pull backward on it, but will not go down.
I'm assuming it's supposed to be locked in reverse or when pulling back on it and have no play, is this normal, or indicative of air in the system?
