Question re lower unit drain plug
Dave1027
I'm changing the lower unit oil. The small magnet that sticks out of the plug and into the oil is loose. Is this normal? I noticed when I pulled the drain plug out and went to wipe the tiny metal specs off it the magnet came right out. It could be normal. It's just that I never tried to separate one.
FunInDuhSun
Re: Question re lower unit drain plug
Not normal.
Replace the plug before the magnet gets lost in the pan.
milehighboater
I agree, replace that plug before anymore use. you don't want that thing to get knocked into the gear set.
Jacket4life
And if you have a LOT of those "tiny metal specks", you have a NOT "tiny" problem. You have serious lower unit gear wear.
