Hi, I'm pulling the top cap on a 2002 Larson 210 outboard model. When winching/pulling the cap off, where are the best anchor points to place the rope? I have 1 cleat in the front, 1 on the outside of each driver/passenger seat, and then 2 on each side of the back of the hull. I also have various "grab bars," but they do not seem as study when applying more than hand presure as there is foam behind them where the backing plates are mounted. The cleats seem to the the only visible option, but I was concerned about stresses as this thing is fairly heavy as the front part has the entire front seating area/floor, as well as the driver and passenger consoles.
I have it loose, and just need to chisel some in the back as the transom cap has adhesive underneath and is being stubborn. Just want to make sure I distribute the load properly and carefully.
Thanks for suggestions!
