Question regarding Volvo penta 4.3 Gi
Jhm1992
This might be a foolish question, but I can't seem to figure out what type of fluid is supposed to go in the small container on the front bottom right of my engine. I have looked at the owners manual and the illustrations I am finding don't label it whatsoever. It is running low on the fluid in it and I can't seem to tell what it is. The tank I am speaking of is the one with the red cap in the photo I attached. Thanks in advance!
Ayuh,.... Welcome Aboard,..... It's the P/S pump,.... Atf or P/S fluid will work,....
Are ya gettin' the spillage in the bilge,..??
How much is it loosin',..??
Jhm1992
Now that you mention it, I have had a little spilling. I just emptied the power steering and refilled it. Should I try filling it up again and see if it holds?
Tail_Gunner
The gi ps pump lays at a extreme angle. Look at the geometry closely as to what is really low or just the oblique angle the pump rests.
Jhm1992
I believe that it is nearly empty. The dipstick for it is basically dry.
