Question
nrechtman
I originally posted this question and now have some additional info
I have a 1999 Searay 180BR, it has a 3.0 liter 125 HP Mercruiser engine with an Alpha One Sterndrive, the stock prop is a 14.25x21 Aluminum Black Max 3 blade prop, top rpm is 4800, what prop would you recommend I change to to help getting skiers up and out of the water, the current prop isn't cutting it.
Here is the info off the Searay engine/drive/prop matrix
1999 180BR
3.0L Merc (135 PHP)
Alpha
2.00:1
14.25 x 21 AL Black Max
944868
4800
I have run the boat and the WOT is between 4100-4200 rpm, and the prop is a 23 pitch, not sure of the diameter, the different prop finders are recommending a 14x21 4 blade Solas Amita E series AL, or a Hustler 14x21 AL some have even recommended 19 pitch
Slip Away
Re: Question
Get a 14 x 20p Michigan Wheel 4-blade Vortex aluminum prop. Part # 992204. You will gain the holeshot and tube pulling power you need, only lose a couple hundred RPM at WOT and a couple mph. But you will have better overall midrange torque and ability to pull watertoys.
Levinz11
Re: Question
Obviously I have a different motor/drive. But, I went from a 3 blade 21" to a 4 blade 19" Solas and my hole shot and general usability greatly improved. My RPM is still 44-4600. I did however lose 2-3 MPH. I would drop 2" to get those skiers up.
QC
Re: Question
I'd go 4 blade 18 if you are looking to get skiers up. No way that boat pulls even a 21 with a load. Despite the listing at SeaRay, there is no such thing as a stock prop. They have that for sales info, but you can tell by your 23 inch info that even a 21 is too tall. 200 RPM per inch is typical rule of thumb, so the 21 would barely get you within spec, and since you are looking for hole shot, a 19 three blade, or 18 4 blade might get you to 4800, and a decent pull out of the hole. Challenge is that you need data to prove it, and the only way to get that data with your boat is to try it ;)
Edit: 4 blade 19 might be perfect, but most 4 blades are even inch pitch.
nrechtman
More recommendations
I just got this email back from Turning point with a custom recommendation taking in all the parameters of my boat, engine, stern drive and WOT and if I go aluminum, going to a 17 pitch
SUPPORT REVIEW and RECOMMENDATION:
We feel that there is a better propeller for your application that was not displayed within Prop Wizard Recommendation #154039. Please see below for your new recommendation.
Top Speed / Performance Diameter X Pitch - Rotation
3 BLADE ALUMINUM 14.25 X 19 - RH
4 BLADE ALUMINUM 14 X 19 - RH
3 BLADE STAINLESS STEEL 14.25 X 19 - RH
4 BLADE STAINLESS STEEL 14 X 19 - RH
Water Sports / Heavy Load Diameter X Pitch - Rotation
3 BLADE ALUMINUM 14.25 X 17 - RH
4 BLADE ALUMINUM 14 X 17 - RH
3 BLADE STAINLESS STEEL 14.25 X 17 - RH
4 BLADE STAINLESS STEEL 14.25 X 19 - RH
Best regards,
Support Team
Turning Point Propellers, Inc.
nrechtman
Re: Now I'm definitely confused
:facepalm: Good luck with that..... hope it works.
That's the problem, I don't know which way to go, I was hoping for one clear definitive answer. I guess I should just go buy a reconditioned 4 blade 21 pitch prop and see how that works. Or I can call Mercury and speak to them.
Levinz11
Did you read the recommendations given?? Your 3.0 will not turn a 4 blade 21" prop. You have to DROP pitch when going with a 4blade. Notice how Turning Point and the users here have pretty much recommended the same props.
Good luck.
QC
Re: Question
If your tach is right, you need to go down to 19 at least. And there will be a huge hole shot improvement over your 23.
steelespike
Re: Question
I'm surprised you suggest a 21" 4 blade when the Turning point posting doesn't mention 21 at all.
Go with a 19" 4 blade very likely will be a 14" prop don't sweat it.You will think you added a supercharger.
Solas props are proven performers.
nrechtman
Re: Question
One of the first recommendations I received was for a 14x21 4 blade, from a local prop shop near me that carries reconditioned props and he has selling it for around $70 ,
steelespike
Re: Question
I think that suggestion was premature.Also as time goes by I wonder about some reconditioned props as a primary prop.
