I have thought about building a swim platform for my boat, 24 foot single sterndrive walkaround. My transom is straight and I was going to just set the platform off the transom a 1/4 inch on stainless brackets. (Instead of bolting directly to transom.) I am mostly doing this for a few reasons. First safety, you cannot climb into my boat, if you fell overboard, as the freeboard is too high. Second storage for a livewell and maybe straping sharks to the platform instead of hualing them onboard. Third, I am thinking that the platform would reflect some sound away from the boat at cruise. Not that it is that loud but any reduction would mearly be icing on the cake.
Now to my question;
I have some experience with glass work but never built anything from a mold. I was thinking of building a mold out of melamine (coated particle board) and then just putting a small radius (fillet) in the corners to smooth the transition from horizontal to vertical surfaces. I am going to taper the front to back and also build the sides and rear to about 2 1/4" thick. I was going to use polyester resin The layup would be wax, PVA, white gelcote then 2 layers of 1.5oz mat, 2 layers of 1708, then a piece of 1/2" marine ply, two more layers of 1708 and then 2 more layers of 1.5 oz mat. I was then going to spray gelcote over the bottom just to seal it all up. I would then take it out of the mold and tape off the areas I did not want nonskid and texture roll some waxed gelcote to the top for nonskid. (This would match the nonskid on the boat. )
Am I missing anything? Anyone with fiberglass experience see anything wrong with this? Does anyone know how much resin I would need? Dimensions would be about 78" x 18" give or take the taper.
Now to my question;
