Ezrider_92356
- Jul 14, 2007
- 426
well today i drilled some holes in my floor with a 2 inch hole saw to check the condition of the stringers they are covered in fiberglass so i drilled some holes with a small drill bit the wood came out a normal collor but i cant tell if its wet or not or if its rotting i drilled a few holes in the transom as well and the wood looked the same i know the transom is starting to rot right around the drain plug i dont want to drill there becouse i cant get to that spot from the outside i dont realy want to drill a hole threw the outside fiberglass. i also suspect the transom becouse the washers from the motor mounts are sunk in a small amount i dont know if they where over tigtened or if the transom is worse than i think with the motor up in the trailer position if i grab the lower unit and hang from it (i weigh about 135lbs) and bounce up and down i think the transom flexes a small amount maby 1/4 inch its kinda hard to tell though because the trailer bounces too when i do that.
