mattsmall1972
- May 14, 2006
- 238
One of the things I've noticed on the engine is that it seems that there's always been a bit of oil on the top of the fuel pump of my 1978 OMC 2.5L Stringer 400.
So today, I'm doing a water trial and the boat's running terrific - it's not overheating (I've had problems with this recently) and it's smooth and fast. However, after a few minutes of running, it "chugs" momentarily but keeps on going. After a while longer, the "chugs" appear more frequently and for longer durations.
I bring it back in. I'm still having electrical problems and my tilt won't go up, so I take off the engine cover to look at it. There's oil splashed everywhere on the side where my fuel pump is. I take this in as another thing to fix on this machine.
On the way home, I realize that the chugging and the oil splashes could probably both be tracked down the same thing - the fuel pump. So here are my questions:
1) Is it normal for oil to be in the fuel pump?
2) If oil is indeed leaking from the fuel pump, this could be an indication that it's going and that the chugging is the result is either it failing to pump or oil being in the fuel.
Thoughts? Anything I'm missing?
