Re: quetion on prop spin out
Forgot something. When you say "get over" if you are talking about getting over the bow wake and planing, bow comes back down, I can cause ventilation also if I am trimmed too far out. Like if I were running at WOT maxed out and shut her down, then punched back out without changing trim position I can make my engine run up the usual 200 rpm which it will hold till I'm blasting along at a pretty good clip then it gets a bite of clean water and settles down.
So I'd suggest if that is what you mean, just tuck the trim in till you get it to stop. If you are really setup high, it may not stop and you'll have to use less throttle for your hole shot and give the boat time to gain momentum before you wind up the prop so tight; like get her up and over the hump with say 3/4 throttle and then hammer down on it.
Course you may need a hot-dog prop to stop it too, which would allow you to come out faster without ventilating.
Dhadley and Walleyhed are good at answering this type of question.
Mark
