Okay I read the engine FAQ on "Awakening a motor". I had a motor sit for 2 years. My first priority is I have water intrusion into the gear case. I see milky white oil oozing out of the gearcase after starting. In the FAQ all it says is if you have water intrusion to fix it...but doesn't say how. So how do I fix water intrusion in my gearcase? Is it just replace the gaskets between the gearcase housing and the lower unit housing? Is there any seals around the water pump that need to be replaced? Seals around the prop shaft or drive shaft that need to be replaced?
Thanks in advance
PS - I have a 'Rude 1965 33 hp.
Thanks in advance
