quick advise: outdoor temps and laying poly resin
Darren Nemeth
I have a half gallon left of poly resin and a lot of glassing left to do inside the boat but outdoor temps sharply dove down to average 60 to 65 degrees the past week here in Michigan.
I am working in the open air outdoors. No access to a garage.
What is the lowest temp I am able to get a good cure out of polyester resin? Can I add more MEK Peroxide and still have it kick at 60 degrees?
I cannot find this information in any FAQs I've looked at so far.
oops!
Re: quick advise: outdoor temps and laying poly resin
yup you can darren.....
60 deg isnt that bad...so dont go to heavy on the cat.
a trick you can do is use a big work light to "fool" the resin ,glass and substraight.
heat the substraight with a light....keep the resin warm till you are gonna use it....
but you are fine at those temps just go a little heavyer on the cat but not much...stay below the 2.5 mark
Darren Nemeth
Thanks, oops. :)
It looks like its going to sprinkle today but if its good tomorrow I'll jump right in the boat and use up the rest of that resin.
lowvlot
I have posted this same question a couple times. What is lowest outside temp. that poly resin should be used?
Yacht Dr.
A loaded question at best m8..
What does your can say ? are you adding cureing agents ?
What is the use for ?
YD.
lowvlot
As to not highjack i will repost my question on my thread. thank you.
