Quick Concrete Question
TwoBallScrewBall
I am setting deck support posts. <br /><br />I have a 18" wide X 32" deep hole that has a 12" thick concrete footer in it. Today I set the posts on top of that in another 9-10" of concrete with anchors on the posts. So now I have about 1.5-2 feet of hole left. <br /><br />How long do I have to wait before I can fill them with dirt? It's 80 pound sacks of "sakrete" from home depot. I didn't see this specification on the bag instructions. <br /><br />Thanks.
Bart Sr.
Re: Quick Concrete Question
You can fill them right away.Concrete will "set" even if it is under water.<br /><br />>>>>>>>HAPPY BOATING<<<<<<<
oddjob
1 day or after what you poured last sets. Are they 4x4?s.<br /><br />Barts right also^
CalicoKid
Just be sure there is some moisture in the dirt as well though. You don't want the dirt sucking the moisture from the concrete, it will not cure as strong with water being wicked away.
mattttt25
kid is correct. leave it a day or so. especially with the cold joint.
TwoBallScrewBall
OK thanks everyone. Yes they are 4X4. Posts are set now and holes are filled. Deck is 1/2 framed out. It's hot out there so I'll be working on it more tonight as the sun sets. <br /><br />Later,
