Quick Outdrive Winterizing Question
wilyesteve
This is my first year with a motorboat.... 5.7 Merc, Alpha one.
Seeing that the glorious Chicago weather is going to be at freezing temps for the next week, I had to rewinterize, so I drained the risers, block, and water pump outlet in accordance with the sticky.
I lowered the outdrive to full down, but I don't see anything about draining the outdrive.
Please confirm that there is nothing I should be draining from the outdrive.
Thanks.
Re: Quick Outdrive Winterizing Question
Ayuh,... Sounds like yer All set...
ziggy
agree w/ Bond-o. ya sound set to me too.
nope, nothing. when full in/down. gravity drains it.
Don S
You will have a power steering cooler if you have power steering, it will need to be drained.
