quick question..9.8 mercury 110 outboard carb question
islandguy33
I was wondering if anyone on here can help me out.
I'm just bought this motor and I'm trying to figure out what year it is so I can order a carb kit for it (was told upon buying that the motor ran but rough, and the carb needed to be re-built)
From cross referencing the serial number which is #4245783 I figured it to be a 1975. But it doesn't look like a 75 motor to me... But what do I know :)
I live in Canada so it may be a Canadian engine but not sure.
The carb says Mercarb on one side and on the other it has 1364-4929 stamped on the body and Tillotson stamped on the blue plastic piece.
Then on the back of the motor (picture) it has a sticker with
P/N 339-6222A4 Feb 04 1986
I'm going to attempt to attach a few pictures I took of it to help out.
Thanks everyone!
Ben
motor - http://i50.photobucket.com/albums/f315/nogolz33/IMG_1038.jpg
SN - http://i50.photobucket.com/albums/f315/nogolz33/IMG_1041.jpg
carb - http://i50.photobucket.com/albums/f315/nogolz33/IMG_1042.jpg
sticker explained above - http://i50.photobucket.com/albums/f315/nogolz33/IMG_1043.jpg
Laddies
Banned
Re: quick question..9.8 mercury 110 outboard carb question
Your motor is a US built 1975 with a tillison carb the part number for the merc kit if 1399-879194026 it's $74.90 US if I were you I would get an sierra gasket kit #18-7007 and inlet needle #18-7295 for about $12.00 US if you need a float it's #18-7209
islandguy33
Thanks!!! If it's running rough do you think its worth buying the 75 dollar kit? or try just shooting some carb cleaner through there at idle to see if I can clean it out? I'm a bit of a newbie when it comes to outboards and don't want to cheap out if it's needed, but on the other hand don't want to buy a bunch of things I don't need :)
Thanks again!!
Laddies
Banned
In 40 years I have never needed one
islandguy33
So in other words you'd go for the carb cleaner?
islandguy33
ok sorry... I re-read your first post and now feel slightly slow :p
I just ordered the Gasket kit, float and needle.
Will let you know how it goes. And thanks a million once again! :)
