hey guys, I got a 1992 90hp force outboard I'm woking on right now. Everything runs beautiful and all is well. I drained the lower unit oil the other day. I pulled the bottom fill plug off and it seemed about maybe a half or less teaspoon of water was right at the drain plug. Then as the dark oil drained there was a very small white vein draining with the oil. Now my question would be, should I replace all the seals and the waterpump, or with that small amount of water could I just replace the drain and vent gaskets and filler up again? AS well, which seals are responsible for water getting into the gear housing? Thanks guys
