quick question?
antonio88
maybe im on the wrong section i hope for an answer anyways, i have a 1989 bayliner with a 1979 85 hp evinrude im planning some paint job to the boat i just wanna know if i can use regular ppg automotive paint?
Tom Maslar
Re: quick question?
If the motor has aluminum parts you will have to use metal etching primer on any exposed aluminum or your paint will come off. You should also spray filler if there is pitting--hope this helps
