Quick Rear Engine Mount Question
TimeZone
Pulled the engine last night to replace the coupler. Expecting to find double wound lock washers on the rear mounts but found flat washers instead.:confused:
I found some mention of flat washers in some threads in this forum, but no clear explanation.
Is it OK to put back with washers or should I get the springs?
Is there a service bulletin or other Merc info regarding this?
Any help is appreciated.
Thanks - Ron
Re: Quick Rear Engine Mount Question
Thanks - Ron
Ayuh,.... I'm guessin' yer workin' on that '05, Merc 4.3l, Alpha, Gen..II,..??
TimeZone
That's the one.
I updated my signature but I guess I should have probably mentioned it as well.
I'm using manual #25 for the job. Closest one I could find.
achris
More fish than mountain goat
Those double wound washers have been removed and a longer mount has been made, so all that's needed is the fibre washer. Yes there is a service bulletin on it somewhere... If I manage to dig it up I'll post it here.
Chris.....
TimeZone
Thank's so much for the quick reply.
I'm off to the shop then!
Cheers!
Ron
