Quicksilver 3000 throttle only button will not disengage throttle lever.
scbackpacker
When I press the throttle only button to disengage the throttle lever to start the engine the throttle lever will not disengage. Everything else works fine. Are there drawings of the a Quicksilver 3000 throttle control available? Quicksilver 3000 is a single side mount with throttle only button located in center of throttle lever, trim switch at top and trailer switch in lower right corner.
Don S
Re: Quicksilver 3000 neutral button will not disengage throttle lever.
Here is a site with a list of the different 3000 controls and modular components. http://dougrussell.com/partscatalog...&coldesc=QS REMOTE CONTROLS VOL. 2&index=2436
The pictures aren't very clear, but here is link to the OEM manual for the controls, which will help you locate the parts.
http://www.4shared.com/file/144897617/4cfd9e4f/Merc_Controls_Newest_manual.html
scbackpacker
Re: Quicksilver 3000 throttle only button will not disengage throttle lever.
Thank you Don the manual has my unit in it:). Happy boating. You take care now.
