Quicksilver 3000 trim issues
scoflaw
Ensign
Not sure where the problem is. Trims down not up. Trailer switch will trim it up. Not sure how to get the 3000 apart to look at the switch
Bt Doctur
Re: Quicksilver 3000 trim issues
trim limit switch can aslo be bad, mounted on the drive
scoflaw
Ensign
Is the trim switch on the ground side or the hot side?
stonyloam
Forget messing with the controller... for now. The likely cause of the problem is the trim limit switch located on the gimbal ring (port side) on the outdrive. If the switch or wires fail your trim up will not work but trailer will. Go into the stern of your boat near the transom and locate 2 black wires that go into two connectors, one with two blue/white wires and one with a purple/white wire (should have 12V when trim up switch is pressed). Pull the black wires out and jumper between the two connectors. Try the trim switch, if it works the problem is your trim limit switch or wiring. If not your control switch or wiring may be the problem.
scoflaw
Ensign
Thanks for the info stoney. Looked back there. real tight, saw nothin. Where's that skinny young guy, with good eyesite when you need him?
stonyloam
real tight,
Been there LOL. The black wires should come through the transom just above the driveshaft behind the engine. The wires are only a few feet long so the connectors should be there someplace. There are two pairs of wires, one goes to the trim gauge, the other to the trim limit. Good luck on finding a skinny kid:D.
scoflaw
Ensign
Turns out, it was indeed the trim limit switch. Question now is, seeing this switch works by the position the two halves are in relation to each other, why does this switch even need to be mounted on the drive? Don't want to pull this boat out, just for that.
