Mercury 115 L6 1984 , s/n 6524946
Got the rebuild kit in the mail today and when i opened up my old pump i noticed some parts are not the same.I know that you should just replace wot is taking off but one of the check valves is different.
I took a couple of pic's to let you see wot i mean.
Can i use the filler block (item c in the diagram) instead of the retaining spring and is that washer/c valve (top right in picture) complete. Should i use the spring and plastic cap also.
Thanks guys.
Thanks guys.
