I have a 1994 Starcraft with a 120hp Force outboard. Was having problems getting it to shift into reverse (forward shifts fine) and ended up breaking the splined shaft on the control box. The control box has a 822195-C1 stamped on it. Can I get a replacement control handle shaft or do I need to go completely new? If I need new, any suggestions on a replacement?
As for the shifting issue (which will probably still be there when/if I fix the shaft), the cables move freely when removed from the motor linkages. Any ideas why it shifts into forward and not reverse?
Thanks
Bill
Thanks
Bill
