Quicksilver control wiring
rainman5
I have a 1982 FishinSkiBarge 16' with 80 HP Merc with Quicksilver controls. There are 3 wires red, black and yellow 10-12 gauge. I was able to hook the red and yellow up they went to the tilt and trim but I do not know where the yellow one goes. The controls have the ignition swith, kill switch, tack, and tilt and trim in them. Any help would greatly be appreciated.
Raymond
rainman5
Re: Quicksilver control wiring
I was able to get the motor to turn over a few times, I wasnt able to tell if it was firing, arms weren't long enough to watch the motor and turn the ignition key.
Thanks
Raymond
rainman5
I now have a remote starter so I can watch and it isnt firing. The motor will turn over. I am still wondering where the solid yellow wire coming from the control box goes, there is also a red and black the same gauge that I found a place for then. . This is Quicksilver controls, I dont know how to find out what model it is, it is a 1982 or 1983. If anyone has a schematic please let me know. I have the clymer manual but no luck with it.
Thanks
Raymond
Chris1956
Ray, What year is the motor? Yellow on a Merc is usually the starter solenoid, or the stator wire. On the later models the voltage regulator provides the stator wire signal on a grey wire to run the tach. On the earlier Mercs, the tach signal is a brown wire.
BTW - The controls should use every wire that the motor has, with the exception of temp gauge and/or overheat, provided the motor is equipped with these features.
rainman5
Thanks Chris it is a 1982 80HP 6234182, the motor will turn over using the igniton switch or the remote starter I bought at Sears. there are several wires in a tubing going back to the engine. These 3 wires solid red, solid black and solid yellow were alone and not in the tubing. The red wire and the black wire went to the tilt and trim motor. I repleaced the stator, but I dont know maybe it could be a swtichbox, trigger or coils. I know that it ran before it was put up. The man that owned it passed away, I bought it from his son that didnt have a need for it. On the switchbox I got readings from the red to red/white blue to blue/blue white
Thanks for all your help
ricksrster
Save image and zoom to be able to read it.
rainman5
Thanks I will check this out today
