quicksilver Power 2 parts
x8052
I am looking to find the prop lock parts for the quicksilver power 2. I know that it is very difficult but thought i may ask. i have the prop A19. Any of them especially spring and it's axle. Thx
Fun Times
x8052 Welcome to iboats!
Here's an Instruction sheet with part numbers for the Mercury Quicksilver Power 2 Variable pitch prop.
https://forums.iboats.com/filedata/fetch?id=7183050 ..., https://forums.iboats.com/forum/gene...ruction-manual
https://www.crowleymarine.com/mercur...rts/2439_0.cfm
https://www.mercruiserparts.com/808920-power2-prop-lock, Mercury Quicksilver 67-808920 - POWER2 PROP LOCK QPD=NO …
Edit: I may have found the lock for sale here, https://greenbayprop.com/media/67-8...lock-for-quicksilver-power-2-props-67-808920/
Depending on what parts you need you could also try searching Mercury Marine Propellers Propeller - Power 2 Parts or quicksilver power 2 propeller parts
x8052
hi, thank you for your reply. All the items appear as not available on crowleymarine and mercruiser parts. Do you have any other resource maybe ?
Also even if someone has the parts broken or non working i could still get them
x8052
If anyone have them, can you give me measures for spring ( length- external diameter - spring metal thickness) and axle ?
chevymaher
I got one not sure what your calling the axle. Looks like if your making one a torsion garage door spring would work. I took the measurements on the carrier as seen. Outside diameter is 1.52 inch. Length of coiled spring. Not including the 2 right angle tongs. 2.62 inch. Spring diameter .2 inch. All measured with a dial caliper.
If you need more to make more of it. I can take it apart for the internal parts and measure them.
x8052
that's great. Yes that is what i am thinking to do, make one. If you could do that - measure everything - it would be very helpful. Axle i mean the nut, where the spring goes. Some pictures of with measures of it could help.
Fun Times
Are you looking for item number 5, P/N 24-823519 ? "Torsion Spring" if yes then there may be a few places you could buy it from still.
List off the part numbers you're looking for to see if maybe someone can help find them too.
P/N 24-823519,
SEA WAY MARINE INCLYNNWOODWAWebsite
CALGARY POWERBT SERVCALGARYABWebsite
KOKOMO MARINEKOKOMOINWebsite
Name City State
x8052
the parts i am looking for are:
Axle/Nut (P/N 823517A1) f - Torsion Shift Spring (P/N 24-823519)
Adjusting Plate (P/N 823521) h - Cam Plate (P/N 823520)
chevymaher
Crowley marine has the cam plate your looking for and a few more odds and ends things. I PM'ed you my e mail. The PM system here is so screwed up it barely works. And it hard to read blinking like that. I see the axle nut on the diagram. I thought that was what you were looking for I will measure that thing and draw a diagram for it for you. There is a complete one on e bay for 500 bucks right now.
Fun Times
Looks like a few places may have these in stock. Might be time to jump on the phone.:encouragement:
823520 = https://www.crowleymarine.com/parts/...repair_stories and I'd bet one of the places shown below may have this part too.... What area do you live in?
823521 =
GREENE MARINE REPR
WILMINGTON
NC
Website
BRUCES MAR SLS& SERV
GIMLI
MB
Website
24-823519 =
SEA WAY MARINE INC
LYNNWOOD
WA
Website
CALGARY
AB
Website
KOKOMO MARINE
KOKOMO
IN
Website
823517A1 =
US BOATWORKS INC
KANSAS CITY
KS
Website
GIMLI
MB
Website
GORDON BAY MARINE
MACTIER
ON
Website
