i have a 1986 regal medalion 185 open bow, it has a mercruiser 3.0/ alpha one setup, i need to remove the throttle/shift lever to replace a cable, any ideas as how to remove it, i got it loose on the splined shaft but it wont go all the way...thanks
It sounds like you have a early commander box they were JUNK to reuse your good cables find a commander II or III by mercury they are a much better box and there are some used ones out there
