Quicksilver Trim Control Problem
Dean58
I have a 88 Slickcraft with a quicksilver control with the switch in the top of the handle. I can lower the unit from the switch but not raise it, this can only be done from the trailer trim switch. Occassionally I will lose power to both switches and will need to take a jumper wire from a power source at he fuse panel and touch the center terminal in the handle switch to regain power. The up does not ever work in the handle. A little wisdom would help me regain my sanity.
QC
Hey Dean. Let's move this to the right Forum. I am assuming this is a Merc I/O Going to move to Mercruiser. Check out this Google search as well: Trim and Trailer switch site:forums.iboats.com
Welcome Aboard!
QC
FWIW, I have had one bad in the handle as well. Exact same symptoms. Quicksilver 3000 Classic, A1.
