I have an Alpha 1 350/260 with a trim problem. I couldn't get it to go down and after changing out the solenoid on the trim motor (one of two) - I realized that there are two canisters for the hydraulics. I filled the one with the two solenoids and by shorting the solenoids the trim works properly. However, I have no voltage at the shifter. I have lights and the boat starts. there must be a fuse somewhere but I can't find it. The red main breaker is fine and I have continuity on the square fuse & bridge on top of the motor containing the two solenoids. I unplugged the four wires that go from the shifter to the motor, cleaned contacts, etc. w/no success. Any ideas on where to look. Again, this appears to be a Quicksilver setup which I find little information on. Thanks.
