Racorr vs Sierra Fuel water separators
muskrat808
Hi- Deciding what F/W separator to put on 1972 140 hp mercruiser ,specifically what GPH rating and Racor vs Sierra . Read the article from Feb 04 Trailerboat mag which says you can buy a Merc Bracket and use either Racor or Sierra filters , but if you get the Racor bracket you are stuck using only the much more expensive Racor filters . Talked with local West Marine and a couple other places and they didn't know what I was talking about . Wondering with a motor that old is the Racor overkill ? But do plan to add a newer kicker running through the filter however .- Thanks
Re: Racorr vs Sierra Fuel water separators
Ayuh,... I'm Shocked,... Shocked I tell ya,... :rolleyes:
Get the Sierra or Merc housing, 'n put 3/8" hose barbs on it, 'n install it....
Merc, Sierra, 'n Napa carry the filters, 'n they're fairly inexpensive...
Don S
http://www.iboats.com/Water-Separat...08414382--**********.156292349--view_id.45101
The above works great on new engines too. Just use a good 10 or 20 micron element on a carbed engine. As far as the sales force in some of those stores, you ask them the price, or where something is and that's about it, They have no clue about what they are selling in about 90% of the cases.
muskrat808
Thanks guys . Still wondering though if Racor are worth the extra price and if I need to worry about GPH ratings . The guy at our local marine shop ( Cooks , in Portland OR ) said I should buy the more expensive higher GPH rated Racor vs the lower rated GPH Racor for this engine . Should I be ignoring his sales advice ? Thanks again
GA_Boater
Bond-o, Did you just happen to watch "Casablanca" by any chance? LOL
muskrat, Get which ever one matches your 140's fuel flow best.
Don S
The filters I linked to earlier work fine with the 7.4's, doubt your 3.0L/140 will cause a problem with flow rate.
Ayuh,... Save yer money for Gas....
