thedukeryan
- Jul 21, 2009
- 298
My battery has been draining over night and I am trying to diagnose what may be pulling power. Shortly before I started having issues I installed a new Pioneer CD player. I have it hooked directly to the battery and spliced the accessory switch in with the positive. Could this be what may be draining the battery? The only other changes that I have made is that I replaced the starter & solenoid's going to the trim pump. If its not the radio, starter or bad solenoids draining it is there any easy way to track the leak down? The battery is almost new and tested good. I also have a deep cycle that didn't test good but didn't test bad either. Would a deep cycle battery on its way out be a possible cause? The boat is a 1990 Wellcraft 233 Eclipse with a 5.7L Mercruiser. I am guessing the alternator is good since the boat runs fine after jumping and charges the battery back up enough to start once it has been running.
