rothfm
Ensign
- Sep 26, 2006
- 915
Almost ready to install my new Alum 100gal tank. The enclosure is a fiberglass coffin rectangle. It will have appx 2" free on all sides except the bottom. Never any foam at all. good breathing space, drains to Bilge.
The original sat flat on the bottom fiberglass of this "coffin" area..I was thinking of installing alum 1.5" x 1/4" Alum strapping along that coffin bottom spaced 6" apart or so. Logic here was to keep it raised off the bottom for drainage and ventilation to avoid corrosion again.
Then thinking about it, any slight movement will be metal on metal, and may damage the tank.
Thoughts on this?
common sense says its a new tank, place it flat on the fiberglass bottom as it was, re-install the stainless straps protected at the corners with a plastic backing etc.
Thanks
Thoughts on this?
Thanks
