Re: raising motor
First lower the jack on the front of the trailer, then put a block of wood on the ground under the skeg on the motor. Remove the top two bolts that hold the motor on, only loosen the lower two in the slotted holes. Now raise the jack, this will lower the transom and the motor will move up, when it gets to the hole you want stop and put the top bolts back in.<br /><br />It's easy and fast.
