Raker II
bassone
Could someone help? I'm running a raker 14 1/2 X 22 ss prop i'm needing to drop between 4 to 500 rpms, rule of thumb would be to go to a 24 pitch prop but i want to go to a raker II which would be around a 23 pitch, they dont make it in a 14 1/2 X 23, they make it in a 14 3/4 X 23 would that work, what would the 1/4" bigger prop do hurt or help, sorry so many questions just dont want to buy the wrong prop, thanks
steelespike
Re: Raker II
Is there a post here with your present performance?
If you could remind us of your motor/boat particulars, present wot rpm and speed
we could be sure a prop change is in order.
bassone
Re: Raker II
im glad u responded, yes i have asked before and u said the rakerII props are 1 to 2 stiffer in pitch, im running a raker prop 14 1/2 X 22 on the triton 180 premeir with a 150hp johnson rpms are between 6 and 6100 was going to try to find a raker II prop and go to a 23 pitch but they dont make it in a 14 1/2 x 23 they do in a 24 what would u do? thanks
steelespike
Re: Raker II
I recall now It did appear you were pretty normal but for the rpm.The 1/4" diameter difference on the 23 shouldn't matter.
Based on the discussion on the Raker ll it seems a 24 would be too much.
