raker prop
delsol
someone gave me a cleaver prop. ss. or my 5.7 23 pitch.
what does a cleaver do..
bob
Lucrestyle
Re: raker prop
from what i understand a "raker" prop has good cupping ( like a spoon) and generates bow lift as well thus getting more boat out of the water. Raker props like to be run on the surface for best performance. try it out and you will see the difference.
delsol
Re: raker prop
mistake sorry its a cleaver prop????? will that hurt the boat..motor runs like crap now..so i cannot get a real test
bob
jimmbo
Re: raker prop
Cleaver props are known as stern lifters. Used with lots of positive trim to hold the bow up they can effectively lift the whole boat up and reduce drag. However they are a surface braeking prop, therefore they aren't at their best when run on a typical stern drive.
Raker is a prop which has a very large rake angle to the blade.
Cupping a prop can change the pitch or the rake of a prop depening when the cup is added. Adding a cup to the trailing edge of the blade adds pitch, adding a cup to the blade tip increases the rake angle.
modsrx
Re: raker prop
i have a raker prop on my 200 hp and it run great on top speed 82 mph on gps
