Ran out of epoxy need advice !
Cast-A-Way
I am in the process of repairing a booboo I did
When I put my new transom in some of it did not laminate properly to the outer fiberglass skin !
as per the advice on the forum I drilled a bunch of holes and started filling them with epoxy.
That seems to work great but I ran out of epoxy now and I can't get any where I live on weekends, I have a small section left to repair and I would like to get it done this weekend so I can put the motor back in ( I/O )
I was thinking of using poly resin ??
I know it gets brittle without matt
Will it bond with the epoxy
what do you think may happen ?
Any other Ideas ??
Thank you
ondarvr
Re: Ran out of epoxy need advice !
It's epoxy only for that job, so you either find some or wait until Monday.
Cast-A-Way
Thanks Ondarvr that's what I thought
Asside from the obvious locations to get this stuff do you have any clues as to where else to find epoxy ??
Home depot ?
Rona?
ondarvr
For location you list Canada, kind of a big place. Just check the yellow pages and every hardware store, I find supplies like these in the oddest places.
