Re: Ran out of resin.
poly is farr easyer to find than epoxy........
id just run to a local dealer.....look in the yellow pages....or call a fiberglass repair shop....even automotive....just buy a gallon from them.
yes, you can use epoxy over poly.....but not the other way round....so once you go epoxy.....you keep using it........
now....the stuff you get from wallmart...(poly)....is waxed....that means, if you apply another layer after it curing, you gotta grind off the top layer of wax.
i wouldnt worry bout the epoxy being stronger in the engine compartment.
even tho, epoxy is way stronger. poly is twice as strong as what you need.
kinda like using a steel girder to hold up a aluminum backyard shed.
