Random Question, lol ! HHO Generator for an I/O ?
Status
Not open for further replies.
cajun32
Has anyone attempted to use a Hydrogen Generator on an I/O to improve fuel consumption ?
A hydrogen leak in the engine compartment could be quite hazardous.
Just curious.
Anchor Management 1
Re: Random Question, lol ! HHO Generator for an I/O ?
I work on boats everyday and people are doing in on there engines but I have not heard of the gen.
Anchor Management 1
Yes people are doing it on there own boats. Experimenting I guess I told them to be carefull.
180shabah
Hydroxy gas has proven to be about as valuable as snake oil. Definately not worth the risk on a boat.
Just curious.
Ayuh,... I skiped right over the Hydrogen Generator,+ went with a Flux Capacitor...
Now, if I could just find somemore Dilithium Crystals, I'd be boatin' for nearly Nothin'.....
CheapboatKev
My boat runs on water
Bt Doctur
Dilithium, not cheap Bondo. I have a spare set you can have,they need re-charging though.
might try Dilithium-Ion cells too
wca_tim
sorry charlie brown: HHO injection = Bologna....
unless of course you're running a blower with a little much boost and need it to be able to run more timing without scattering the bottom end.
water injection cools the intake charge and lowers combustion temperatures...
My understanding is that the reason that some people see performance increases with water injection on their cars... is that if the engine antiknock system has retarded timing to deal with poor tune or poor fuel quality, water injection will drop combustion temps a bit and allow the engine to move the timing back to where it belongs... in other words, it wouldn't do any good in a properly tuned engine running on good quality fuel...
there is no scientific basis for the burning of water improving combustion otherwise... modified combustion equations posted on the internet are pure bs and fundamentally flawed.
mkast
It wasn't a question of poor fuel, the technology didn't exsist at that time to refine a higher octane fuel. Water injection (50/50 mix of water/alcohol) was still used after 115/145 octane fuel became available. This was used on supercharged and turbo supercharged engines. Compression equals horsepower, the higher the compression, the more horsepower.
Higher compression also equals less reliability. This development took place before anti-knock systems.
PiratePast40
They do that in submarines all the time. The hydrogen generator splits the water molecules for oxygen to breath and hydrogen to run the reactor ;).
wca_tim
hear you... I was referring to why the average joe blow that hooks a water injection system up on his late model sedan or economy car sometimes reports an increase in efficiency, etc... rather than adding it to allow you to run more compression and timing on a boosted engine.. you're dead on of course...
wca_tim
well... they do kinda have a nuclear reactor to power the electrolysis...
and fuel efficiency is a little different consideration in their application than ours...
joeyr
It takes roughly 3 times the energy to produce (split) hydrogen as you get back from it. No, not a method to improve efficency.
I don't agee with this quote, I can split molecules with my HHO generation using under an amp and producing a great deal of hydrogen/Oxygen. The trick is to build a good oscillator circuit, and tune it to the "right " frquency for the type of stainless steel plate, and size and thinkness of plates.
I don;t have my generator hooked up to my boat yet, as i can't overcome the timing issues with my old engine. Also the danger of the generator rattling around.
Don't half *** this one boys and girls as that stuff is REALLY explosive. 2300 meters + a second
HT32BSX115
Ok,
I'll bite, I get it for the oxygen.......but what do they use the hydrogen for in a submarine?
HT32BSX115
Um huh?
More than $30 of modern house electricity would be required to simply PRODUCE an equivalent amount of Hydrogen gas to one gallon of gasoline! How can that be efficient?
This thread has completely diverged from anything resembling "Repair and Maintenance of Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives "
It might fit perfectly in Non-Boating Technical Topics or even Stupid Human Tricks While Boating/Fishing !!!
I shoulda been a moderator!!!
Aviator5
I vote for Stupid Human Tricks.:)
Aviator5
Only in the waters of lake Erie lately.:D
Status
