Re: Rare Ted Williams 7.5 Electric start
My after market manual doesn't mention a battery pack.Only that it uses a 12 volt battery.The battery should be connected with the negative to ground.The motor has a combination starter/generator.<br /> If the motor has been run without a battery there is a fuse a diode and possibly the armature that may be damaged.You could give it a try to see if it will crank but if the armature is damaged it may not.If it cranks won't charge you don't need the generator to keep the battery charged.<br />A good quality battery will start the motor many,many times before it needs a charge.<br /> You could ask the scott guy at <br />web.a-znet.com/~scottguy.He may be able to give some details on the system.
