I have a 1993 pro 17 bass tracker with the factory 40hp evinrude. Fresh rebuild bored .30 all new parts. Motor runs like a champ but is turning a little much for me. It has a 3 blade 11-3/4 x 17 prop. I have no idea if its stock or even close to what it should be. The anti cavatation or ventilation plate(not sure which is correct term) is about level with bottom of boat.
Here is what it does
WOT 6100-6200
MPH 29-30
Now this is with the motor trimmed all the way down, it planes out quick but when I trim the motor up I see now difference till the prop starts to cavatate/ventalate/slip out of water? Then rpm's go up and boat slows down. But doesnt seem to matter what I trim it at.
Over 6000 is to high for me so i back it down to 5500 and it runs about 24-25 motor seems happier. But when I go from 5500 to 6200 the boat accelerates very fast and just feels smoother on the water. Its like the boat is happy over 30 and the motor is happy at 5500 or less.
So can I get 30mph and about 5200-5300 with 5500 max rpm with a prop? Or am i asking to much and should just run it the way it is? Thanks for any help or advice in advance.
And im not deadset on the 30 and 5200 if you know of another route i should be shooting for im open to any suggestions.
WOT 6100-6200
MPH 29-30
