rattle/ clunk when putting into gear
sqhurt
have a 89 vip with the 2.3 with cobra outdrive. I just purshased this boat not long ago. But finally got it all running right and tried to put her in gear to see what it do. Well it made this rattle/clanking noise then stopped, and sounded fine. The cover for the motor was off and when I tried it again the lever that the shift cable is connected to, the bracket for the esa shakes up and down when the rattle/ clanking is happening. Is this normal or do I need to do the adjustment on the cable? Thanks
Howard Sterndrive
Re: rattle/ clunk when putting into gear
sounds like the normal sound of the lower unit clutch dogs engaging to spin the prop.
don't hesitate when shifting, and it usually works better/quieter when in the lake (more resistance on the prop)
sqhurt
OK, great. Thanks Alot! This is all new to me and was little worried when heard that noise. It sounds better if didn't hesitate shifting it. Thanks for the the reply.
BonairII
You def don't want to put the motor is gear slowly. Idle all the way down...and just shift it quickly into gear. Easing the shift lever will a rattle because the dog is riding on the gear instead of postively engaging(meshing) with the forward or reverse gear.
Ayuh,.... Like Outboards, 'n Alpha outdrives,... Shift 'em Briskly,....
dirt23
outdrive will only go in reverse
tring to figure out how to post help please
