Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
I want to replace the inlet hose on my 1993 220 Cobalt 7.4 liter. I can’t even see where the other end is from the water pump. Disappears behind the engine. Any advise?
Thanks I replaced the raw water pump, fuel pump, circulating pump and most all hoses except for that one. It’s the original I’m sure and very hard and inflexible. Oh yeah and the starter (that was fun). Thanks for your feedback
One other question? I replaced the thermostat and housing with the new style, it has these check balls that install in one of the fittings. How tight should they be adjusted, just till the balls seat (light tension) or more tension?
Huh, the one I replaced was a one piece could double as an anchor. The new one is a two piece with a brass thread-in tee, which is where the check ball Assy goes. Should I just leave it as is or remove the check. Engine runs cool at about 160
