On my Q4 tahoe, at the bottom is a bronze thru hull where I can use to pull out the oil drain for the engine. What are the chances of me being able to thread into that on the inside and use it as a water pick up instead?
At the end of the season, I'll remove the fittings to drain the engine oil out.
What i'm trying to do is avoiding putting yet another hole in the transom for the wash down pump pick up.
Any thoughts?
Thanks.
Any thoughts?
Thanks.
