Raw Water Pump Question.
I own a 1996 Pro-Line 231.
Mercruiser Engine MCM 5.7 LX EFI
Stern drive : Bravo two
I have a need to rebuild the raw water pump. I have the pump on my desk next to me. I need to purchase a rebuild kit, Here is where the confusion comes in. My pump has a part number on it :46-807151 It is the 2 piece pump body. I can find rebuild kits that contain the plastic body and impeller and gaskets need for a rebuild of the pump. I can also find kits containing impeller and gaskets. My problem comes with the number on the pump. The kits I have found are numbered as follows: 46-80751A12 ,A8, A 9. Are all these numbers interchangeable and can be used with my pump. I have no numbers after 46807151 such as A12 A8 A9. Just a little confusing. Thank you for your time.
Daniel
