Raw Water Pump Seal
kk lowrider
Is it possible to change just the seal on the raw water pump pulley I have water coming out of the weap hole after changing the impeller on my volvo 4.3 2000 but to be clear was leaking before I changed the impeller, but now it leaks worst.
havasuboatman
Ensign
Re: Raw Water Pump Seal
yes, that seal can be changed. finding a new seal. or more correctly, someone to sell you one, can be tricky. most places will tell you that you need to change the whole assy.
Bt Doctur
I`m thinking he means the engine circ pump . If so you will need to replace it as a unit.
Don S
The 2000 model VP engines have an engine driven raw water pump. It does have a weep hole and they will leak there. You can replace the seal. Not sure what the condition of the bearing will be, but the seal is replaceable.
kk lowrider
Thanks to all for the help I took the seal out and I'll replace it first if that doesn't solve the leak then i'll replace the whole unit, thanks again kk
rodbolt
my experience, about every thrid impeller change, replace the pump.
they dont last for ever.
kk lowrider
Replaced the seal and solved all of my problems, Thanks for all the advice that gave me the confidence to fix this problem. I appreciate everything KK
Edge180
I think I found the same problem and I want to fix it myself. You can see the steady stream of water beneath the raw water pump. Is this what your leak looked like? I just can't believe a pump would wear out after 6 years of relatively minimal use each summer. Is this normal?!
I've got a 4.3VP build 2002 I'm pretty sure. The impeller's never been changed. I just noticed the leak this passed weekend after hooking it up to the hose and ear muffs after storing for the winter.
How long of a job was it for you?
kk lowrider
This was not bad at all and if you are mechanically inclined you can do this in about 1 hour tops. Just remove the impeller bracket then the impeller housing 4 small brass bolt then remove the fan belts then the 3 large allen bolts on the pulley then remove the pulley and gently remove the center seal without scraping the shaft replace the seal part #827247 the sealing ring $8 bucks at the dealer or you can order it right here. I would replace my impeller and o ring while you are there. You can do it. If you have any questions I will be happy to help KKlowrider
Edge180
So, the sealing ring replacement looks to have solved my leak problem. Not a drop feel into the bilge when I started it up. I'll follow this reply up with my experience- Thanks KKlowrider for your instructions; couldn't have done it without you!
Question now is, I thought I read somewhere that I should be seeing water spit out of the exhaust/ prop. When I started her up after fixing the seal, and ran her on the ear muffs with a little water running there was no water misting or anything coming out of the exhaust.
Now, I don't remember water coming out if there last year when I started it on the ear muffs either.
I double checked everything, inlet and outlet hose installation, direction of impeller (replaced with new), hoses pointing down, etc. but don't know how I could have done this backwards.
Maybe because I didn't let the engine run long enough that water did not have time enough to circulate in the engine after having been drained during installation?
Any thoughts?
