Raw water pump VP 4.3
Lawnpro979
Hey all....
Getting older here. Can't find post about the raw water pump. It looks like mine is out. It was replaced about 1.5 yrs ago. Not sure if this is normal. But also rather rebuild it instead of a new one....
Any help? Thanks
do some searching on iboats. the repair kit is an easy install.
is your seal leaking, or is just the impeller needing a replacment?
Lawnpro979
No leaking. Took her out this weekend and she over heated. I'm sure it's just the impeller. It's hard for an old fat man like me to get in there to replace it......
Thanks for replys
if its not leaking, most likely impeller. about $35 for the kit.
could also be debris that you picked up plugging the power steering cooler. either way, someone has to get in there to work on it.
