I have a 5.7l mercruiser alpha 1 Gen 2 with a new style raw sea water pump. I worked great a month a go. Put it on the hose in the yard no water through the pump. Check all the hoses for clogs, found none. Replaced the impeller still no water. I even put the boat in the water thinking low water pressure at the house, still no water through the pump. However i did not replace the black housing that the impeller sits in. It does have some small gougeson the inside of the plastic but not major. Any help will be great.
