Raw Water Washdown Installation
FreeBeeTony
I am going to be installing a raw water washdown pump in my '84 Grady Offshore.<br /><br />Questions:<br /><br />1) where should I install the pump? should I install it in the engine compartment? the boat is an I/O.<br />2) should I try to locate the output near the middle of the boat?<br />3) I have also heard of using this same pump for live wells?
rodbolt
Re: Raw Water Washdown Installation
mount it where its easy to access. most shureflow blaster type pumps have an auto pressure switch and can run dry and can stand a static lift of 3 to 5 feet. most rubber impeller type pumps can stand a static head of 3 to 5 feet but cannot stand a dry run condition long. most fixed plastic impeller type pumps must be mounted below the hulls static water line and wont self prime at all. <br /> I prefer the shurflow pulse type pumps with pressure switches cause I can mount them above the hull static water line, leave them on for periods of time and with a t fitting and valving they can be used as livewell fill pumps as well as washdown pumps.
DangerDan
a Plastic impellar type can be added above the water line however you have to add a primer bulb to the line to get a prime. just a thought. My livewell pump was installed in the motor well below the water line and a diverter valve was installed in the line at the rear bulkhead to give me a washdown line. I have an automatic livewell switch that I can switch to manual to wash the fish goo off of the floor when I need to. If your not using a livewell you have many choices. Theres nothing wrong with an addition below the waterline if installed properly.
