rd-19-c johnson fuel to oil ratio
mntboy
hi, my name is josh could anyone tell me what the ratio for oil to gas is for a 1958 35 hp sea horse rd-19-c. Also don't know alot about the older motors is this a good one?
Vic.S
Re: rd-19-c johnson fuel to oil ratio
The recommendation is that it should run on 20:1 or 5%
see http://www.evinrude.com/en-US/Owners-Center/FAQ/OilAndFuel
That would be 2 pints of oil in 5 gallons of gasoline, using a TCW3 2 stroke outboard engine oil.
For smaller quantities that is
6.4 fluid ounces per US gallon
8 fluid ounces per UK (Imperial) gallon
50mls per litre
tmcalavy
Correct...24:1 is also acceptable with todays, modern TCW-3 marine oils. They are good/great motors...lots of torque/power and reliable when maintained correctly.
mntboy
Thanks alot guys!
