Re-built carb
LuckyPenny
I am getting a re-built carb and wondering if the float is set at the factory or if I have to take it down to set the float level?<br /><br />the re-build facility is Champion.<br /><br />The carb is a Rochester QuadraJet.
rodbolt
Re: Re-built carb
should be preset. if done correctly its plug and play.
Don S
Re: Re-built carb
Yes is should be right if you ordered it for the proper marine application. If it's an automotive carb, take it back and get a marine carb.
