Hi, I am about to re-install my alpha outdrive. I have a coupla basic questions about it: The new gasket kit i got for it has one too many rubber o rings then I could find places for. It looks like I need an o ring for where the raw water passes through and 3 o rings on the input shaft. My kit came with 5 o rings. It also looks like the ones i suspect are for the input shaft are narrower then the ones that are currently on there. <br /><br />My second question is what kind of grease to use on my gimbal bearing? one of these guys at the local marine place said to jut use OMC wheel bearing grease, but i wanted to get a second opinion. <br /><br />My third question has to do with the water I found in the bellows. I had a little bit of standing water in there, I could not find the source. The u joints were not in the least bit rusty, so I assume it was not in there for long. I found no apparent cracks, or leaks of any kind for that matter in the bellows. Anyone know where the water could have come from? <br /><br />Thanks in advance!!
